    Ensoniq5's Avatar
    Mar 2013
    No, idling is unlikely to change immediately by unplugging the ISC since it's just a valve. Unplugging it won't cause the valve to suddenly move (quite the opposite) so no change to the idle speed would be expected. However it should change when switching AC on or off to counter the extra load BUT ONLY if the throttle closed switch has told the ECU the engine is idling. If not, the ECU is trying to run the engine based on sensor readings (MAF etc.) and the ISC isn't in the loop at all. You will need to fix/verify the TPS before you can know whether the ISC is working or not.
    TN Wagon - Died of old age
    TP Wagon - Died before its time (murdered by the ex wife)
    TJII Wagon - Hail damaged and finally traded away after 150,000 relatively trouble-free kilometres
    Skoda Scout - Has a lot to live up to...
    GRH's Avatar
    Mar 2013
    hmm makes sense. i guess in this case only way to fully verify the tps is to probe it while its plugged and engine running and see if the engine vibration messes up the continuity or not.
    i ll be on it tomorrow
